Old 06-08-2012, 03:19 PM
olddog olddog is offline
Two points:
1) Peak Hp tells nothing about the torque over the entire rpm range. The low end torque of a stroked FE is way more than a high strung SB that make it's peak Hp at 7000, even if they make the same peak Hp.
2) Rear end and suspension makes a huge difference in traction. IRS vs straight axle. 4 link 3 link also matter.
If you listen to what the guys on here say, you get the impression that a stroked FE connected to an IRS is a very difficult thing to launch.
