Old 06-08-2012, 06:14 PM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
If you listen to what the guys on here say, you get the impression that a stroked FE connected to an IRS is a very difficult thing to launch.
I've got a stroked FE (428 bore 4.13 X 4.25 stroke) in a 3.27 IRS car. I'm not sure how it compares upon launching compared to 3 or 4 link, but its not like its out of control or unmanageable. Then again, I'm used to 11 sec 1/4's on 2 wheels too. I haven't driven a roadster w/FE in a 3 or 4 link to compare it to my IRS. Granted, I don't do a water burnout like at the strip then pull into the staging area where its super-sticky, but as long as the tires are warmed up, spirited street driving and launches aren't a problem. I think it is what you get used to.
My engine wasn't dyno'd, but with a list of all the parts in it, most experienced engine folks tell me it would probably be 520-530 at the flywheel.
Anyway, it is a moot point now, as I blew the whole bottom end out of it last Sat at Hallett Raceway west of Tulsa. Now I'm planning my next FE stroker.
Anyway, my opinion........500-600 hp at the flywheel is about right, but you know how opinions are.
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
