Old 06-09-2012, 03:49 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by Gaz64 View Post
Dan,
Your measurements are vague, measured in respect to what?
The point of alignment is the input shaft HAS to be in line with the crankshaft.
Your numbers are twice of .006, and .006 is too much off centre in my book.
Your bellhousing and/or block doesn't have dowels?
Keith Craft built motor - yes it has dowels. Measured with a magnetic base set on the crank flange and 1 inch dial indicator reading at 90 deg intervals around the bellousing register for the transmission. Numbers have to be divided in half for runout so they are well under .006.
