Old 06-10-2012, 06:15 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
the tko600 is really like a wide ratio tranny with an overdrive, gear ratio's similar to a wide ratio toploader, but with an overdrive. If you would run a wide ratio toploader, you can run a 3.07 rear ratio, and then in 4th, you would not need an overdrive. With a close ratio toploader,you need to run about a 3.54 rear ratio. I think the toploader is simpler, durable, maybe easier to fix.
If you want a race-like tranny, get a close ratio, either a toploader, richmond 5spd,etc. which have gears spaced about 23% i think. If you want a tranny for economy, i'd just get a wide ratio toploader with a 3.07 rear. Yes, you can get a tko600, but i'd get the 0.82 5th. If you already have the toploader, you can do a gear change.
Any of them will be fine.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
