Old 06-11-2012, 05:36 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by strictlypersonl View Post
Just put the transmission output centerline at 3.5" (+/- .25") above the top plane of the X-member. If you have the Jag-based suspension, the differential angle varies as the suspension goes up and down. Matching angles with the suspension unloaded will not work.
We've used that height spec for 30 years, and never had a problem with the drive-shaft.
Bob - this is a timely note. I was just getting ready to write about this subject after playing around with an angle gage on the drive train this evening. I'll set it at 3.5 inches.
Thanks
