06-14-2012, 05:11 AM
AR
Originally Posted by patrickt
Not true. The sound of a big block does not come from the size of the space in the cylinders, but rather it comes from the size and shape of the metal of the block. Just like a bell, it's not the size of the "hole" that makes up the underside of the bell, it's the size of the crown, waist, soundbow, etc that makes up the bell itself. I have never heard, or felt the sound, of a small block that was the same as a big block. Now, I firmly believe you can make a SB just as powerful as a BB, but you can never make it sound the same, anymore than you can make a small bell make the same sound as a big bell.
Some of the difference in sound between various engine makes results from differences in the firing order. I don't know if a SB Ford has the same firing order as a FE - probably does. And then compression and cam timing and exhaust size/configuration contribute enormously too.
