Old 06-19-2012, 02:43 AM
Zedn's Avatar
Zedn Zedn is offline
Is there club rego in SA? Might simplify things.
As for cost, I have spent low 30s on mine so far with only a small amount of part left to buy and then rego should see it under $40k. Thats with buying my body and chassis for $6k. I have done everything myself except drive shaft. That is with fabricating everything fuel tank, windscreen frame and various other bits and pieces. I'm just polishing up a washer tank I also fabricated.
You can build a car for $40k but it takes a lot longer unless you are lucky enough to work full time on it. If you need to pay someone to do it I would buy the most complete kit you can regardless of cost because it will be cheaper in the long run. Sounds like you can work on it yourself though.
Some cheap 2nd hand cobras have been changing hands with the current economy. This is a good way to go without rego headaches. Alternatively an unfinished project on eBay.
