Old 06-19-2012, 08:01 PM
400TT's Avatar
400TT 400TT is offline
Originally Posted by Modena View Post
Craig: what diff is the Pace chassis setup for? I understand you are using fabricated suspension components, I'm assuming you are not fabricating a diff......
ZF 8.3" unit as used by Holden in VE Commodore, also in Camaro etc. Used by some of the largest Cobra manufacturers overseas as well. Wide ratio choice, reliable and price competitive. Also you have bolt-in upgrade centres for large horsepower installs. Everything else in the rear is fabricated, uses a pushrod suspension setup, but have kept the bearings oem compatible in spec, so that we keep our and owners options open.
www.absolutepace.com
