Old 06-20-2012, 05:09 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Default Illinois and Seatbelt law
I'm interested in finding out if anyone knows what the state of Illinois requires regarding seat belts.
For the passenger side I would like to install a Lap belt and an anti-sub belt. Will this be acceptable to the State.?
Installation a double shoulder harness type belt will be a task. And to do it properly to eliminate/reduce the chance spine compression I would have to do a bunch of cutting of the body and install steel mounting points back to the frame in the trunk. Then it creates a another issue that in a roll-over the passenger is strapped in and exposed. I know that a roll-over is a severe condition and front and rear impacts are more realistic where shoulder straps will help.
A single shoulder strap will also have it's installation issues.
Driver side is no problem as the shoulder straps will mount to the roll-bar at the correct angle for limiting spine compression injuries. And the driver has the protection of the single hoop roll bar.
I look forward to your comments.
Thanks, Arthur
