Old 06-23-2012, 10:41 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by dls141 View Post
I replaced the old small rotor front brakes with 11" Grenada rotors and GM metric calipers using the Heidts custom bracket on the old Mustang II spindles. The setup seems to work well.
But I'm a little concerned that I had to remove the old backing plate/dust plate from the spindle since the new rotors are a good 2+ inches larger and it just wouldn't fit.
But now I'm wondering if I should try to find a larger plate that would work with the spindles and larger disc or is it OK to just drive it like it is?
Any ideas? Experiences? Thanks!![url='http://www.clubcobra.com/forums/picture.php?albumid=1089&pictureid=8078']
i have the same setup installed, from Heidt's, i opted for the wilwood calipers, and the old "hats" as they are called, don't fit, to modify them would make them useless anyway so i have been running for 5 years without them. the only purpose i see them for is to keep dirt and debris from getting on the rotor. with the GM ones you might be able to use a GM hat, i dunno......you'll need to redrill for mounting at the very least.
lol i don't do alot of dirt road cruising so i don't see much of an issue in not having them, i have noticed there are Chinese universal ones out there, but i have more important projects to worry about to focus on them right now
Fred B
