Old 06-24-2012, 05:02 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Mine was also passed with wilwoods on the front on 330mm 2 piece rotors....I am upgrading to six piston calipers at present and have 17" roh 3 piece rims ....on a trial fit the bolts on rims are just touching the calipers ...Thanks to stiffy's advice above I think I will only have to remove 5mm off the rotor and make a new caliper mount and it will cure the problem...Thanks Stiffy
