Old 06-24-2012, 11:25 AM
DanEC's Avatar
DanEC DanEC is offline
Jeeez - no body warned me I should have dropped the radiator in the car before installing any front suspension parts. I thought I would take a few minutes this morning to drop it in and it won't go - the lower outlet kept getting hungup on the pass side upper a-arm bolt. After taping and padding a bunch of things I was finally able to twist and turn the radiator enough for it to slide by that and then thunk - it hung up on the sway bar. So I had to remove the bolts from it so I could pull it down and get the radiator to fall into place. And then of course the top mount and baffle are a very tight fit and took a lot of fooling with. My 15 minute job took about 1-1/2 hours finally.
