Old 06-25-2012, 05:54 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
One of the main advantages is the two piece dissapates the heat much better an keeps the heat away from your wheel bearings..... The cast iron take the heat straight to the bearings
