Thread: 351W dyno rwhp
Old 06-25-2012, 07:48 PM
Beastly's Avatar
Beastly Beastly is offline
Cobra Make, Engine: Fiberfab international classic cobra
Default 351W dyno rwhp
All
Just got back from a dyno trip and am not sure if I am where I should be. Here is what I have.
351W .30 over
Trick flow TW 170 heads
comp cam 508/532lift 222/232dur
dual quad edelbrock 500cfms
MSD ignition on a 6AL
Timing at 34 total advance
My results on a mustang dyno all numbers are at the wheels
max tq 289lbs @ 2800rpm
max hp 280 @ 4700rpm
TQ remained almost flat across the dyno thru 5200
HP started at 160 at 2800 and rose at a 45 degree angle thru 5500 up to 280hp.
I am just not sure if this is the right numbers for the set up I have? I know I can make more if I go single large 4bbl.
