Thread: 351W dyno rwhp
Old 06-26-2012, 10:26 AM
DAVID GAGNARD's Avatar
351W .30 over
Trick flow TW 170 heads
comp cam 508/532lift 222/232dur
dual quad edelbrock 500cfms
MSD ignition on a 6AL
Timing at 34 total advance
Based on the limited info,I'm comparing this engine to another 351-W I know of with very similar specs, dynoed at around 325 HP at the flywheel......assuming your engine makes 325 hp at the crank and it made 280 at the rear wheels, that is a 13% loss,which would be outstanding......
I'd say for what you have,those numbers are in the correct ballpark..
Switching to an air gap dual intake and 600/650 double pumper and a good tune, I'd bet another 20 to 35 hp would be possible....
David
DAVID GAGNARD
