Old 06-28-2012, 12:49 AM
COBRANIP COBRANIP is offline
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
Morris:
"If you can move your rack back so there is a 10* degree difference from the steering arm on the upright......and ball joint of the rack..... the car Will track around a corner with ease..."
Are you saying the tie rod (as viewed from above) will form a 10* angle from the centerline of the rack? With the rack behind the pivot point of the of the upright steering arm.....or in front of the upright steering arm?
(i.e. the tire rods are angled "forward" or "back"?)
Thanks,
John
P.S. of course a diagram is worth a thousand words....
