Old 07-04-2012, 11:52 AM
crASH's Avatar
crASH crASH is offline
I'm 6' 3" and fit in SPF without adjustments. Unique will build to suit. I just talked with them about deeper, dropped, driver footbox with altered dash.
Backdraft and Lonestar have longer wheelbase and will accomodate the "larger" driver very comfortably. I am sure ERA and Kirkham can accomodate. And there are others.
It has been discussed MUCH on this forum and if you search you will find lots of detailed discussion. One thing I will mention is if you look at used, which can save a ton of dough, some of the cockpit dimensions have changed with some of the builders over time.
