Old 07-05-2012, 09:09 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by TimeForACobra View Post
Both good ideas... Thanks.
Actually, the bolt runs more vertical and has nuts on both sides.
Should the bolt pull out through the bottom so that I can slide the rubber mount out?
So, this might be my problem... The top nut is off, jacked the engine up just a little, the rubber mount moves up and down with the top of the bolt but the bottom nut just spins. Is there something inside the motor mount that I don't know about? Or did the bolt snap? Seems like there is something, some kind of thin plate, between the rubber and the frame.
Thanks again, I probably won't have time to look at it again until the weekend.
without a pic its hard to tell but from what your describing that "plate" is probably part of the mount and the rubber has separated from it.
Fred B
