  #25 (permalink)
Old 07-06-2012, 07:42 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Originally Posted by CowtownCobra View Post
Car is running great, but recently it has developed a backfire on the left side (none from the right). Letting off big time leads to a big pop, while normal slow downs lead to mutiple smaller pops. It didn't use to do this. What do I check for, fouled plug, bad plug wire, or what. I'm clueless...
Ideas?
I developed the same problem very suddenly yesterday, except the popping was coming from the passenger's side. I had been swapping out the valve cover gaskets right before the problem began...when I got it back home I found that somehow I had "dislodged" the distributor cap and it was "cocked" slightly rearward....naturally, the sparks were flying all over the place. Once I had it secured again the problem went away.
Check yours...it doesn't need to be off by much.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
