Old 07-06-2012, 07:45 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
You might be better off just going to NAPA and getting a replacement ECU. Without being able to pin point the offending component on the board you're kind of whistling in the dark and with the ECU being of such an old design I would think you'd be hard pressed to find someone to diagnose a particular element for you.
DonC
