Old 07-07-2012, 04:57 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Satallion112, yes it's possible. You need to resolved the centrifical advance and get it set right first. On the vacuum advance you want it adjusted to around 10-15 deg. advance. You have to watch your idle; if you are hooking it to manifold vacuum it raises the idle which raises the centrifical advance. You think you have more vacuum advance that you really do because the centrifical has kicked in.
Wayne
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
