Old 07-08-2012, 07:25 AM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
G'day.
Firt check for a bright spark to earth from the coil. Then connect a 12 test light from earth to + side of coil. Light should come on. then place test light on - side of coil, crank engine, and the light should flash. If not, you have no signal. Start from there.
JD
