Old 07-08-2012, 09:25 PM
Steno Steno is offline
Cobra Make, Engine: Factory Five with EFI 5.0 w/ other stuff bolted on
When you turn on the ignition on the car you should hear the fuel pump run for a moment before you go to start. If you hear it run,the pump is probably good to go. I had an issue with the fuel pump relay once when the car sat for an extended time.rrplaced the relay...no more problem!
Good luck, Sten
