Old 07-09-2012, 07:28 AM
jwd's Avatar
jwd jwd is offline
Originally Posted by mreid View Post
Great article on vacuum advance, but several misinformed posts with blanket statements like "running mechanical secondaries on the street is wrong". Just demonstrates a lack of complete understanding. Power to weight ratio is a bigger determinant than street vs. strip. Also, some street cars also run on the track and need mechanical secondaries. Properly tuned mechanical secondaries on a high power to weight ratio vehicle will always perform better than vacuum secondaries through the range of driving conditions. Add vacuum advance and you have a killer combination.
You are the one who doesn't understand carbs. The second quoted statement above proves it.There's more to a DP carbs. than just the mechanical secondaries. I've changed a lot of cars over to vacuum secondaries and the owners couldn't believe how much better the car ran. Maybe that's why NONE of the big 3 car makers ever used DP's. DP's are designed for the track, not the street.
Run whatever you like, I'm outta here. I've been building and tuning for 40+ years. My knowledge comes from actual experience (on the track and the street) not from a Summit/Jegs catalog.
Jim
