  #34 (permalink)
Old 07-09-2012, 08:26 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by jwd View Post
Okay, I was reading it as 36-38 initial plus centrifugal advance. Now it makes sense. I know what causes the surging. When I tune a car and encounter it, I change the vacuum can to one that had a little less total advance. Usually only a reduction of a few degrees is needed.
Jim
Oh - yeah, I can see now how it could be read that way. I understand.
My BB Chev runs low vacuum due to the big, old-school cam and I had to purchase a special vacuum canister that starts to pull in at 6 inches vacuum. There might be one out there like it with less total vacuum advance but it was easier to make a little bracket that mounted over the arm and had a tab that stops the rod from advancing the entire way. That way I reduced the advance that was kicking in while cruising on the road and stopped the surging. Cruising down the road that surging/missing can be really annoying even if you understand what is going on.
