Old 07-11-2012, 07:16 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You might want to consider opening up the side clearance on the connecting rods to allow more oil to sling up on the cam/lifters----and or, use rods /bearings with a squirt hole.
Restricting the oil flow to the tappet gallies isn't done because the rollers need less oil--its done usually because the engine has a fully rollerized upper end and doesn't need so much oil flow so it can be directed the excess to the lower end of the engine-------
