Old 07-13-2012, 01:14 PM
NFLDMNBB's Avatar
NFLDMNBB NFLDMNBB is offline
Cobra Make, Engine: B&B, FR302
I have had this happen. It can be the stops. I had a Mustang that did this and after adjusting the stops I had no more problems. If the stops are not adjusted properly what happens is the gear does not mesh as much as it should and with a little pressure it will easily disengage.
I would suggest adjusting the stops two flats at a time and see if it doesn’t improve if not eliminate popping out of gear.
Roger
There are two kinds of people - those smart enough to know they don’t know, and those dumb enough to insist they do
