Old 07-14-2012, 03:59 PM
russgelberg russgelberg is offline
Cobra Make, Engine: FFR, 5.0L
No luck. Just replaced the TFI, no change. The cap & rotor and wires are all new also.
I remain convinced that it is not a part that went bad. Instead it is something loose. It worked perfectly the last time I used it 3 months ago. I turned it off. I immediately tried again and it started perfectly. I turned it off. It sat 3 months. Now it wont start. I replaced the fuel filter and fuel pump. The coil. The TFI. Sounds exactly the same no matter what I change. Grrrr.
Any thoughts? I appreciate whatever you have.
I've checked all over for loose connections.
Thanks again.
