Old 07-14-2012, 07:24 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Think it thru
Some questions to answer
Where are you going to store the single post lift? You can't just drive over it
both lifts are higher than the cobra is low. You'll need to drive onto 2x12 ramps to get the car up over the lift. and if it is the single post, you have to remove the center section of the ramp to get the lift under the vehicle
Pricing isn't that much difference from a two or four post.
If you're that close to Indianapolis, get Greg to come out to your shop and show you how to fit a two or four post lift into it. You'll be much happier.
Paul
www.65shlb.com
www.prdcrrct.com
