Old 07-16-2012, 09:14 PM
PDUB PDUB is offline
Question
Originally Posted by tcrist View Post
Yumski,
Let's see if I am following you correctly.
1) Before the work was done it only over-heated going slow in traffic (city streets) and then when you would be driving faster (freeway speeds) it would cool down and not over-heat.
2) After the work was done it stays cool when going slow in traffic (city streets) and now over-heats when driving faster (freeway speeds).
3) You are still using the same radiator as before.
4) The only change was the water pump and electric fan with a shroud.
Is the fan turning in the correct direction? (again, should be ok because it is not over heating at slow speeds)
If it ran cool at higher speeds (freeway driving) before than one of the changes messed that up.
Terry could be onto something here... if the fan is rotating backwards, i.e. blowing out the front, it might cool fine at slow speeds where it has enough power to overcome the motion of the air being pushed at the radiator. Once you get up to speed, the fan might be working against the forced air, effectively making a dead zone for air-flow at the radiator. This would allow colling at low speeds and overheating at high speed.
It would be a simple fix, if it is wired backwards...
Good luck!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
