Old 02-26-2002, 07:45 PM
OhBuoy OhBuoy is offline
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Rear Brake Lines
I have a 95 3.27 Rear end with Disk Brakes. I picked up hard lines from Breeze, and they fit well. They sent me a flex line, but there are two problems with it:
1) My rear end does not have the mounting holes for the bracket.
2) If I had the holes, the flex line would be too short to meet up at the frame junction.
I called B&B, and the recommended a part that I was able to get from NAPA. This adaptor presented two problems:
1) Again, I am missing the mounting holes.
2) I would need to make custom hard lines.
Has anyone else came up with a solution for this? If I could put a tee at the top of the pumpkin where my hardlines end, fasten it, and run a flex to the frame I would be set. Can anyone think of a longer flex that would terminate in a tee with heavier hose?
Tom
