Old 07-19-2012, 08:51 AM
Don Don is offline
Default GoPro Suction Cup Mount
Attempting to use the GoPro Suction Cup Mount on the dash of my daily driver, dash covering is less than 100% smooth. The mount will not adhere. Probably air leakage in creating the suction.
Hesitate to use the flat or curved adhesive mount, received the following from GoPro Tech Support. But, might have to just accept the adhesive mount could be permanent.
" The adhesive mounts can be pried off but it does take some force and there is a possibility of damaging the surface that they are attached to.
To remove the adhesive mounts safely, you can use a hairdryer or heat gun to soften the adhesive and slowly peel it back. This will not damage the surface and it will be unlikely to leave any adhesive on the surface. If any adhesive is left behind it can be removed using nail polish remover, rubbing alcohol or similar. Please check that the solvent you use does not harm the surface to which the adhesive is applied to before you start.
Please note, once you have applied and removed the adhesive, you can not reuse the adhesive. "
Any suggestions on using a GoPro suction cup mount for the dash with a surface less than 100% smooth. Attaching the mount to the windshield is an option, but visibility is impaired
http://gopro.com/camera-mounts/suction-cup-mount/
http://gopro.com/camera-mounts/flat-adhesive-mounts/
http://gopro.com/camera-mounts/curved-adhesive-mounts/
