Old 07-22-2012, 05:39 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
i would first do a leakdown test on all the cylinders and a coolant system pressure test which of course it should fail. if you had blown a head gasket to the degree it sounds you would probably notice some cooling system abnormalities, hoses coming off, excessive coolant filling the overflow bottle, etc. i would lean toward intake gasket failure, and as barry says, check your angles.
