Old 07-24-2012, 04:30 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Just a thought here, I recently experienced the same situation at the track in my coupe. Checked all the above including having all my tires re-balanced...it turned out to be my rear u-joint bolts had managed to come loose a tiny bit. Three of the four bolts has loosened because I failed to recheck them after installing my TKO 600. Simple and cheap fix if you don't count all the extra steps I went through to get to the u-joints.
Clois
"Let's roll"
"Be part of Something Good
