  #127 (permalink)
Old 07-24-2012, 12:05 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Main portion of the belly pan. This is the bottom side, or the part you would see if you were looking under the car.
This is the other side of the belly pan. The two little pieces that are riveted on are to direct air into and out of the diff cooler.
The diff cooler sits just below the drive shaft.
Front portion of the belly pan. The scoop is for additional air to the radiator.
