Old 07-24-2012, 05:10 PM
olddog olddog is offline
Originally Posted by jhv48 View Post
I think if you re read what I wrote, that is exactly what I said. I never mentioned the disc. Pressure plates have been known to crack or throw a weight and cause just this type of vibration.
Ok. We agree. Sorry for any confusion.
When I said clutch, I meant only the clutch plate.
When you said clutch pressure plate, I thought you meant both the clutch plate and the pressure plate.
It would help to know if this is a problem that just started and was not there before, or if this was a new build. I had initially assumed a new build when a suggested the wrong off set balance flywheel/dampener. A problem just starting out of the blue, most likely is something came off or the dampener slipped.
