Old 07-26-2012, 05:26 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Buzz, I would really like to see measurements of the cockpit included if possible. I have been trying to get these on the various brands. One thing that most don't know, including some manufatures is that there are low, medium and high bodies. They measure from a low of 24" to high of 27" from the main floor to the center rear cowl deck.
The measurements I have been collecting are basic. They are:
1. From the rear center cowl deck to the main floor.
2. The height of the door at the latch to the main floor.
3. The body length and width of the cockpit (inner most points).
4. Length from the drivers firewall to the rear bulkhead where it meets the floor.
5. Across the seat the distance from the tunnel to the door.
What you are trying to do is great. One issue that has to be resolved is car version. Like FFR they are now on the Mark IV. Most other manufactures have not numbered or kept track of the changes. Another example is Shell Valley, when they started up again they now use the higher body that is 27". How do we resolve this? Maybe just a manufacture build date and if it varies from someone elses there would be another entry. Ideas?
Wayne
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
