Old 07-26-2012, 11:20 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Default Minimized Spreadsheet
I've listed the criteria for original. The format is all screwed up because I tried to copy-paste but maybe you will get the idea. I have suggested tabs for 427, 289, GT 40, engines and tips. How can I post the full blown spreadsheet?
Cobra Manufacturers
Updated: 7/6/2012
Contact Wfridrich@Comcast.Net if you have updates
Manufacturer Original 427 Cobra
Web Site WWW.ShelbyAmerican.com
Model 427 Cobra S/C
Type Complete
Manufacturer, Location Shelby American, Venice, CA
Notes
Approximate Number Produced
Retail Cost New $6,000
Typical original complete cost $6,000
Range of Used Vehicles $750,000
Standard Items:
Battery
Body Aluminum
Body Parts
Body Prep
Brake Lines
Brake Master
Brake, emergency
Brakes, front Girling discs, 11 5/8"
Brakes, rear Girling discs, 10 3/4"
Bumpers
Carpet
Carpeting
Chassis Tubular type chassis based on two parallel main members.
Colors
Dashboard
Defogger
Doors
Drive Shaft Safety Strap
Electrical
Electrical, Switches
Exhaust
Firewall
Foot Boxes
Fresh Air Ducting
Fuel Line
Fuel Tank
Gas Cap
Gauges
Glove Box
Hardware
Heater
Hood Scoop
Horn
Instruction Manual
Interior Panels
Lights
Lights
Mirrors
Oil Cooler
Paint
Passenger Air Vent
Pedal Box
Radiator
Rear End Type
Roll Bar
Seat Belts
Seats
Shifter
Shock Absorbers
Steering
Steering Wheel
Stripes
Sun visor & wind wings
Suspension, Front Independent coil springs with parallel arms
Suspension, Rear Independent coil springs with parallel arms
Tires
Transmission tunnel
Trim
Wheels
Windshield & Visors
Wipers & Washer
Dimensions & Capacities
Wheelbase, Inches 90
Length, Inches 156
Height at Screen, Inches 49
Width, Inches 68
Front Track, Inches 56
Rear Track, Inches 56
Fuel Tank Capacity, gallons 18
Front Wheels 7.5 x 15
Rear Wheels 9.5 x 15
Tires: Front
Tires: Rear
Rear End Ratio
Ground Clearance, Inches 5.5
Empty Weight, lbs. 2,355
Weight with 351 Motor, lbs.
Weight with 427 Motor, lbs.
Weight with 460 Motor, lbs.
Optional Items:
Subjective Advantages:
Subjective Disadvantages:
