Old 07-27-2012, 12:41 PM
Default No right stuff here
Rick Parker Rick A good RTV sealer from GM, Ford or Honda will last as long if not longer than the right stuff. Right stuff drys and cures too fast. Over time it hardens. 10 & 15 years on a motor build without a leak with gray RTV. Have never seen Right stuff last that long. Other down side is cleaning of removal. If job is a couple of years or less in age, a good sharp razor blade will remove from surface. Longer time needs chisle and hammer or grinder. Only down side to RTV grey is curing time of 24 hours. You can still move gaskets around within the first 2-3 minutes. You don't have this with Right stuff.
Mongoose 930 The grey RTV will work better than the cork gaskets on the front and back of the intake. Need 2 guys to install manifold and install the distributor quick to center and others have said. Just make sure that the ports on the manifold and heads match the ports on the gaskets. Also check the coolant passages for gaskets not blocking flow. This happens on the Fel Pro 1247 ones and need to trim openings and then RTV both side of gaskets. Good luck. Rick L.
