Old 07-28-2012, 10:30 PM
Barnsnake's Avatar
Barnsnake Barnsnake is offline
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Since the problem is primarily when significant torque is applied, I would take a very long look at the mounting of the rear-end center section. If it is rotating the pinion upward under acceleration the mis-matched driveshaft u-joint angles would cause exactly the symptoms you describe.
Jim
A Gnat! Quick, get a sledgehammer!
