Lippy, I ordered my ERA with the front sway bar only, drove it for about 5000 miles. The ride was very good without the rear bar, but I thought it had a wee bit too much body roll and understeer for me. After installing the rear, it was almost dead neutral in handling tending toward slight oversteer (in some conditions, but I prefer that), and the ride is somewhat stiffer (which I also prefer). I would recommend getting both , but it is a simple bolt-on addition, so go with your gut. If you add it later, you can compare the with/without handling and ride, and decide which is best for you.
Ken
