Old 07-30-2012, 02:20 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by daverascal View Post
What about using a vacuum gauge, I used one to set my idle mixure screws. then I read you can set your timing with one as well.
Yes it can be done, but also another crude way to get the engine running.
A pro uses the positive stop method via the spark plug hole to find true TDC, then mathematically marks the balancer from 10 - 50 degrees BTDC.
Gary
