Things to check: thermostat & cap, fan turning in the correct direction, standard pulley sizes (no undersized crank pulley/oversized waterpump pulley) and on a small block, water pump rotation in the correct direction.
If these are OK, nearly always overheating at a stop indicates an air bubble.
Most Cobra owners go into denial about this.
It is the cause in a large number of these cases....
Your radiator sounds big enough.
Just sayin,
Tom
