Old 07-31-2012, 12:58 PM
Goopie 18 Goopie 18 is offline
Cobra Make, Engine: SPF 2473, Roush 427R
tube does look fragile. I must have knocked it loose. I like the idea of upgrading from the plastic. The place that has been recommended above is only 1/2 hr. away. Simple job to replace? If I remove the oil filter and crank the engine with the coil disconnected oil should pump out of filter housing if I have oil pressure?
