Old 07-31-2012, 01:25 PM
jhv48 jhv48 is offline
I would buy a cheap oil pressure gauge at your local parts store (less than $15) and hook it up to the oil pressure outlet on the block. A local mechanic might even lend you one. Then crank the engine. If no oil pressure shows on the new gauge, you have other problems. my bet is you cracked or knocked the stock tube loose.
Jim
