Old 07-31-2012, 01:12 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
The owner has replaced the mechanical fuel pump, not the oil pump.
The system will stay self primed if the oil cooler hoses run down hill to the cooler. If may have difficulty self priming if they run uphill.
Crank the engine with the gauge line off, then you'll know which direction you're heading.
Gary
