Old 07-31-2012, 03:38 PM
DAVID GAGNARD's Avatar
After cranking the engine and 10 seconds of running, things should be primed up and you should see oil pressure.......
I would try another gauge and pull the distributor and spin the shaft with a drill to verify you do actually have oil pressure before doing anything else......
David
DAVID GAGNARD
