Thread: Sticky problem
Old 08-03-2012, 09:57 PM
RODA's Avatar
RODA RODA is offline
Cobra Make, Engine: Classic Revival LS1 6spd
Leigh,
Peel the carpet back, a heat gun may help but may also just melt the carpet.
Once the carpet is up go to Tradelink and buy a 500ml bottle of clear primming fuild, its the clear version of the red stuff the plumbers use to clean P.V.C pipes with before they skick then together. This stuff removes just about anything, we use it at work to prep stuff with before stick it together. If that does doesn't work I have some Sikaflex cleaner that will work.
I am at the factory at the moment I can bring a heat gun home if you want it.
Rod
