I think I would replace the fuel pump eccentric with one with the hole in it. Ford Racing part no. M-6287-C302 is for the 460 engine and also works with the FE engines. It has the bolt hole for a 7/16" retainer bolt. Be sure your dowel pin is long enough to extend into the hole in the eccentric. Also, be sure you have the heavy washer on the retainer bolt.
I tried to drill out the bolt hole in an eccentric for a small block, but the steel was so hard my drill bit could not make a mark in it.
