Old 08-06-2012, 09:42 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
So when you say adjust at the pedal. you mean you let the pedal come up higher, or, you are in effect pushing on the rod, so the mc doesn't bottom itself out. I have seen slave cylinders with screw adjustment. You let the cylinder bottom out, adjust the rod with a bit of slack. So you get maximum travel.
JD
